pneumatic cylinder
  • Thread starter Thread starter Trasmec
Trasmec
Hello I kindly ask how to handle the stem of the cylinder back and forth giving measures.
after you have bound the pieces (a concentric bond between the stem and shirt, and one of the distance between the bottom piston and the bottom shirt), you can create two configurations, one for the open cylinder and one for the closed cylinder, going to change the distance bond in the two configurations.
as first message I recommend you read the regulation and present yourself in the relevant discussion in the solidworks forum.
to solve your problem you should put the concentric to lock the direction and I would use the distance of advanced couplings to define minimum and maximum distance that must make the cylinder.
I attach an image for greater clarity.
