filippo4825
hello to all
are at the first autocad weapons and I have the need for a mechanical piece design for university examination, to draw a tilted line of 10.5° to the right from the y axis, which departs from the center of an arc.
Now I activate the polar pointing, customize the grades with 10.5, click line, first point on the center of the arc, but I do not appear the degree chosen in the "points" recommended, at the time of the choice of the second point, instead all the other "wines" for any degrees, predefined, one after the other (even if I did not choose to make optional degrees appear). I tried to set one of the default ones (e.g. 45°) and it works perfectly, while one of the default ones with the decimals, in my 2012 autocad version is 22.5°, it also does not appear once chosen in the tips during the creation of the tilted line, so it is as if it did not accept the degrees with the decimals. How can I do that? Can I forget some surgery?
thanks to all in advance
