Tarkus
Hello, everyone.
I happen to have to export to dxf developments created with solid modelers (e.g. inventor) to then send to laser cutting.
often these developments have figures with atypical curves or spinlines.
However, not all laser cutting software (for example mine) read the splines but only lines or strings.
on message board users,I partially solved by exporting the file to dxf version 2000 or antecedent.
in this case the atypical curves are translated into polylinee and therefore I can explode them and get a figure composed of many lines.
the problem is that these lines are really many, e.g. a radius arc 300 me breaks it in lines of about 0.15 mm.
from here the question:
Is there a parameter to be able to change so that you have a bigger resolution?
something similar to viewers for the visual resolution of the arches....
thanks in advance of answers
