polysuperficial link
  • Thread starter Thread starter Sasso SP
Sasso SP
I have a question to ask you.
which command should I use if I have to connect two polysuperfici maintaining the tangency?
for now I extract the edges and through a sweep 2 tracks and some curves I build the surface and then collect it.
the command you are looking for is: _blendsrf
creates a fitting surface with the possibility to set the type of continuity: g0 g1 g2 g3 g4
