porte aperte, porte chiuse
  • Thread starter Thread starter braunfish
braunfish
I'm drawing metal doors.
in the drawings that I have to create, I have to make views both with the open doors and closed in the same table. (the door rotates around the axis of the hinge).
I impose all the constraints I need, then activate them and disable them so that the door stands where I need it.
the problem is that the design is updated. Can't you set 2 or + "statuses" of positioning and recall them in the design view?
Yes, with the representation of position at the level together (expand in the browser in the environment together with the folder representations), then when you put on the table, in the input window use the position that interests you "more visible", then with the command "overlapping view" you can place on it in the dotted position representation, or re-plan another view with activate the second configuration.
I try
Meanwhile thank you, it seems to be exactly what you do for me
