portion printing / scale printing
mario cant
Hello
I would like to print from one of the current views (I say view and not table), to understand from one of the planimetric sections, only one part or portion Is it possible to do that?
Considering that in the print window there is no button / command that allows us to select the part or portion of interest, I wondered how it would be possible to obvious!
Then... ..this part, possibly selectable, would respect the scale?
In the meantime, I have another doubt.
Supposing you want to create a table > rightly you will have to use a cartilage .....supposing to create a table a4 you will use cartiglio a4 (21x29.7).
This paper mill has its exact measurements that do not take into account the print margins of the printer you use.
If my printer has print margins, will I have to adapt (modify) the paper according to those print margins? ?
Supposing you have more than one printer whose print margins are different from each other, you will have to create many cards for how many printers do you own?? ? ?
as you work in these terms.
but don't you first change printer/plotter print margins? ?
“cut region” .......ok, I had already made some attempts in this sense and I happen that by adjusting the region’s pane this does not exclude the inserted quotas. i.e. hides the walls, doors, windows etc. but not all the quotas present.
Is this a problem known or just me?
the fact that you have to operate directly on the chart and do not have the possibility to choose the portion interested in the printing phase !!! !
on the issue of documents > print margins:
as you know the various cards have their size matching with those of the sheets iso > acting on the margins of the printer / plotter you will have to bring these to zero > ergo the square of the cartiglio coincides with the outer margins of the sheet.
at least for prints on sheets of small sizes a4, a3, a2.
Now what I want to understand (I have not yet made proof) ....modify a cartilage, regretting it, compromises the print scale of the chart?? ? ?
Is the graph printed in the present scale?
there is the option "cut annotation".
if the elements attached to the annotation are visible (e.g. the walls of a quota) even in part, even the annotation (the quota) remains visible. in this case, the record must be hidden "manually"
the sw "ragiona" (mainly) for the use of the boards, in the printing phase.
you can set many tables, with all the iso/anse sizes, etc. you prefer.
duplicating the same view, on each of them you can set the portion affected by the press, and import it into the specific table
No. the scale of the view is independent from the size of the table.
if you use a portion of the view, with dimensions that exceed the size of the table, part of the same portion of the view will be external to the "card lines" of the table
Staff online
