position representation
  • Thread starter Thread starter MauroM
MauroM
do you think there is a way to suppress/remove visibility or to make objects disappear using rapp.pos, and of course make them come back when you are in "main" ?
position representations, also called configurations, serve precisely to show not necessarily the minimum/maximum positions of a cinematism or other, but that is, it is part and as of a configuration rather than the other.
apart from the fact that just try, however I don't come back:
in a position representation,main or not, if you remove visibility to a component, you also remove it in other positions.
If you want/you don't want to see a component, use the view representations, or suppress it using the detail levels. .
I probably misunderstood... what I meant is that at the same time when the rapp. of position changed I also wanted to change the view conf. or level of detail...with only one click not two, obviously you can not do. Hi.
with just one click you don't do (or at least I don't know how) but on the design views you can combine representations, positions and levels of detail... so many combinations are
I press that what follows is brain and I'm aware of it, but maybe you're comfortable: you can get a .ipt file which is just the combination of the location representations and detail levels that interest you.
in the axieme go to -> level of detail -> new replacement -> comes together and create the file choosing name and position -> in the derived axieme window choose the representations tab and combine them views/positions/lod as you are interested. .
the idea is right, unfortunately I do not use the derivative substitute because I think it is dangerous because it is not automatically updated but only to .... "manina".
