positioning of 2 figures
  • Thread starter Thread starter djdanny
djdanny
Hello.
Forgive me for the banality (probably of the question.
I have a problem.. .
I made a circular sheet (one cylinder) and I created 4 hexagonal cuts (for inserting threaded rivets).
basically how can I now align hexagonal holes to cylindrical holes (the 2 parts in sheet to be coupled)?
the insertion bond does not work, the joint does not recognize the center, I try to bind by axis, but I can not then work on the game of height... I'm going out a little crazy
thanks to who will answer me
create an axis on the first part (passer for the center of the hexagonal hole and perpendicular to the hole itself) which you will then use in the assembly phase.
Hello, there are 2 ways
the 1st is to use the "central point from closed line"
_foto__651.webpthe second solution is to create the sheet punch which automatically creates a cylinder ø0.5 (which will not be downloaded on the dxf) to be used later with the bond "insert"_foto__653.webp _foto__652.webpI'll coach you. _foto__654.webp
thank you very much was what I hoped to receive
can I use it to ask where it is possible to download some materials like s235jr, c80,c40, or possibly recover all the technical characteristics and then be able to recreate it?
Thank you very much
