possibility to save in previous formats
  • Thread starter Thread starter Alex222
Alex222
I hope this topic goes well for my question, with autocad 2010 you can save the designs so that for example autocad 2005 me open them?
I read that you can do through a program on the official site, which converts the file, only that little program can not install it on win 7 64bit, tells me that it is in comaptibile with my so to 64bit, while having downloaded the program for so to 64bit.
So it works the same if I when I save by name, select that the file must save me for the 2004 autocad version?
with autocad 2010 you can save up to the r12 version of autocad!! ! ! !
so it works.
Otherwise, logically, what would the possibility of saving in previous formats???? ? :frown:
the only thing, take into account that some features introduced in the latest versions, with 2004 are not displayed and/or lost its functionality (see dynamic blocks and directors).
But if you don't use them, there's no problem... .
ah ok thank you, the problem was that on the autodesk site it was written that to make sure that I could open my 2010 autocad designs with a previous version it served to strengthen that little program.
ok thanks 1000
ok thanks 1000
that program can serve you for example if you save with autocad 2010 in 2010, and then you want to open that file with an older autocad version, which is not possible.
If, of course, already saved in antecedent format, the problem does not arise.
