powermill
  • Thread starter Thread starter pirataviola
pirataviola
Hello many times I create of the repetitive engravings that is the same figure repeated several times, which I would like to give a precise order of sequence work, if the order from powermill he will work perhaps beginning from the beginning of the drawing but then instead of following the order i.e. to pass to the neighbor jumps and goes where he wants,so that there is the automatic reorder but is not sufficent, I do not know if there is way, maybe no way?
Of course you can. depends on the type of processing (grossing, finishing, pattern, feaure etc... ).
the "reorder" does not hit anything. in some you set in the settings menu, somewhere there is "level or pocket" for example.
It would be good to know at least the version, and a "thank you" for the time I spent driving you for morphing wouldn't hurt for sure. . .
when I can send you
when I can t send an image to show you I need the reorganization, you know I have an old powermill verse but when I launch the installation freezes at half and you say the wizard stopped, but this version turned on my computer missing something nn so, is there a reason why you stop the installation?
hi, I happen to make code engravings with a bulino, using a pattern, and if I understood correctly, to affect hello, for example, it makes you first c then it or so; to a course of powershape, they said that it respects the order of creation of letters, but I am not so sure... so once the path is done, with the command "reorder" I do it manually, letter by letter, i.e., select the path of the c and click moves down, then the i and click moves down and so on until the end, eye cominque to the junctions, so to raise the tool between one letter and the other, I hope to be explained, hi
thanks great advice,nn know if you can recommend a friend to a version of powermill the 7006 old but when installing it in the computer window7 at a certain point it stops giving message that the installation nn happened yet says my friend that on the old computer xp was fine,
honestly I don't know why you don't turn on seven, you have to see if it is a 64bit processor, so it should have in the directory c, a folder called " x86 programs", and it needs to be installed there, it could try to reduce uac to the minimum and temporarily disable the antivirus and I don't remember if on seven0.00 there is or less windows defender (as on 10), that it turns power6 too, but I don't know if it changes something, I can tell you, I can tell you, I can tell you. .
but, at first glance it doesn't look like seven but 10, in that case it can be windows defender that breaks the boxes, maybe once disabled everything I told you, try to see around the disk if it has created some powermill folder and delete it, then try again the installation, if it's just not, maybe it's incompatible, so you have to opt for something more recent,
ok you the photo taken from window 10, I think your advice is right because in window7 powermill it worked, nn it was easy to install it but it worked, then you had to restore the computer and now we find it from head, however we will follow your advice thanks.
a last thing, probably banal, but you remembered to throw the executable as administrator, because as you will know better than me, from seven forward, if you skip this simple step, many programs do not install,
small clarification on the "reorder" command:
to move a series of paths that make up for example a letter, to first reorder them, use the command "placed at the end" or "place at the beginning", so avoid moving them line by line using the command "placed at the top" or "place down" as I had indicated, hello.
thanks to the advice
Hello,it is also possible to reorder the patterns before performing the tool path. access from the pattern change menu.
select the pattern to edit, dx mouse button and select edit curve from the drop down menu that appeared to you. on the menu above there is the reorder segments command that offers you a set of options.
to you decide the best order and then calculations
you have been helpful to me I can reorder and change the pattern, but you say that before making the path I can give an order maybe I can't because I have powermill 5005 non so....
