Ecathe
Hello, everyone! you would tell me where to find families of prefabricated panels in c.a. with insulation?the typical prefabricated shed panels. in particular those with incarceration. .
ecathe
ecathe
Sounds like a good idea. try and let us knowhi! a few days ago my previous thread with a new domanduccia: I am continuing to look for families of prefabricated panels but without results, unfortunately! meanwhile I think of other roads to bypass the problem...according to you if I did them as a continuous facade putting as element of the panel the walls of a family created ad hoc?? I tried and in theory very theoretical (but really much) could go. Do you have any advice?
no, I'm sorry, never had to deal with industrial sheds (if not for an examination at university)I tried with the facade but when it replaces the glass a wall of 28 cm I must be 100% sure that it is right otherwise it does not make me practically change it!boh!!! Have you ever dealt with the sheds in prefabricated elements?
excuse the delay but I was away on holiday a few daysIf you have a family of tape windows, instead of using the above procedure, in the "window panel" you can insert the tape window.
No, I didn't. However I re-porved (to understand how to do) and in practice just enter the window positioning it exactly on the grid line and then move it to a later time. in this way it allows to "bucare" two panels.... have you eliminated the horizontal dividing line between the two panels?
