precise position detail view compared to model
  • Thread starter Thread starter Catafratto
Catafratto
Hello everyone!
I wonder if there is a system to "win" a view of detail to the table's gemotria, as well as you can change and quote/winch sketches that manage sections, split views and crops. I tried but I couldn't: I hope I'm in touch! I would be comfortable because I have a series of repetitive tables where the structure stretches and I have to move the circle of detail every time, nothing but if you can avoid well come.
dx key on the detail ball --> associates.
Too bad that 90% does not work, you should focus on a work that you have identical in all pieces.
In fact, we do not understand why every type of treatment of the table should follow a different logic.
It would suffice to substantiate everything in the presence of a pilot sketch and you could manage everything more neatly.
Another thing that makes me look familiar is the impossibility of aligning views to more than one reference, and not being able to block them within the format.
Thank you very much, just what I was looking for and I would never find it because I was obstinate to look for the sketches-guide. in my current case it works perfectly (I touch the jewels while I say it) because it is the table of a set and the area in particular does not undergo variations.
Isn't it that you're pulling a rabbit out of the cylinder for broken views? something that leaves me the table of the model always "designed equal" to the varying length without needing to manually record the unexpected view symbols. . smooth axle type with threaded ends, to understand.
