crimas
hi to all I am new to the forum, I expose you my problem in practice I have a dwg file where there are the coordinates of some points that will have to be placed in a machine and necessary for so long to have the list of these points following an order from me set. guest spots draw metal punches depicting the various numbers; If we take for example the one as attached the numbers will have the following order and have the origin of the axes on the top left where there is the red ball.
I have already tried to use extinct but does not give me the points in order gives me the right coordinates though I set the usc on the point 0.0 fixed by me.
I tried to use some lisp but they don't give me the points in order. the ideal would be to have a tool that allows me to select the point and to send and download the coordinates of the latter on a text document and then proceed with the second point and so on for all points.
I know it's a little complicated, but thanks to all those who will answer.
