crispo
I have a problem in using the "righello" tool to measure very small distances. I explain: in the architectural drawings imposed the units so that 1 corresponds to 1 meter. If I have to measure distances that are less than a centimeter, then let's talk about millimeters, when I activate the command to measure I see that the ruler moves to shots with irregular intervals, as if the snap mode was activated, but without a regular grid. The problem arises when, for example, I go to select the second point to measure, sometimes the cursor is as if it stops at a point other than the one chosen. to be sure of the distance I have to pull a line from point to point and check in the property window how long it is.
precise that I have a software that uses an oem of autocad 2010 and that in fact is autocad with some restrictions. with the autocad demo 2008 I don't have this problem and I don't want any system variables or options that I don't know.
