presentation and...
  • Thread starter Thread starter Jeanmart
Jeanmart
Good morning, everyone.
this is my first message and I would immediately take advantage to have some suggestions from all of you.:cool:
for about 20 years I have been involved in design for passion and I have realized a few years ago some product in the field of furnishing accessories.
I'm just looking for a advice on how (such as technique) to make a particular I designed.
I'll draw you a schematic design.
as you can see it is an element that (in the figure in 2 identical pieces) that allows a rotation on a 45° plane.
I would like to stimulate all cad3d designers in looking for the best system to couple the 2 elements on the 45° floor taking into account that:
the coupling (crew, screw, screw+crew to cup, pin and cups etc.) must ensure the rotation of 90° possibly without shock (drying) of the 45° planes and with a minimum friction.
the elements may be printed in plastic material, die-cast, micro-cast, printed by sheet (with obvious changes to the attached design).
I am personally directed towards a sheet metal stamping (0.5 - 1 mm) and a coupling with rivet. However, I have no experience on this type of processing and the techniques used (lack of coupling with rivet and perhaps interposition of nylon elements).
: the rotation pin must have a central passage hole. :rolleyes:
who wants to undergo ideas or even develop functional prototypes (paying is meant) or simply discuss how much above can contact me via mp.
