press error in pdf
  • Thread starter Thread starter wikilivia
wikilivia
I have a problem every time I want to print a pdf by autocad: where I have solid fillings I create strange white stripes on the solid itself (see photo), you know what the problem is? I also tried with the updated version of adobe acrobat xi pro but nothing. .
(I did not find any arguments in which this problem was actually dealt with, if I was wrong and there was already something, sorry. )
thank you in advance to those who will help me.View attachment PIANTE PT PLAN (1).pdf
attaching the file could be analyzed, but in the eye it seems that those rows are drawn entities and placed as visualization over the retini
Perfect!
basically here it says to be a question of displaying adobe ( mah.. ) and "transparency press" in autocad printing.
Thank you, I hope to solve it!
you cannot work on the settings of the pdf reader because if you pass it to others you have to force them to change settings only for your file.
another suggested solution is to change the type of retino and put it a scale so small to display it as full, but it is a bypass of the problem.
if you read the last post the solution is to print with the pdf printer of high quality autocad. I tried and it worked
I know this, in fact it is an escamotage that I can use until the pdf remains inside the studio.. and until it has to be printed.
tried also this but the problem persists
I tried by bringing the resolution to 2400 but the problem is still: here the only thing that seems to work is the selection of "transparency press" in the autocad printing stage, suggesting that gives someone in the link.
thanks to suggestions
specific type of pdf printer I use.
I have 3 types at work, not installed by me, including the high quality one.
There are no problems, pdf such as those attached above once you print do not almost ever present the lines that at video you see white, is as said a question of visualization.
