press with "island" command
  • Thread starter Thread starter Roberto800
Roberto800
kind all,
I would have the need to print a p&id of a fairly complex process highlighting, from time to time, in different prints, a particular line and leaving the rest in transparency, that is to understand what you see in the monitor when you highlight a group of lines with the command "isle the players of the selected objects".
use autocad version 2016.
I thank you in advance for your feedback.
select everything, minus the affected line, and set the transparency you like.
first of all thanks to the answer. so doing I go to change transparency in all layouts and not the one desired, so if I have 10 process lines (places in 10 layers) and I put the transparency of the first nine lines, in all layouts I will have the transparency of the first nine lines.
to me instead it serves that in the first layout you have the transparency of the first nine lines excluded the tenth, in the second layout the transparency of the lines from 1 to 8 and 10, while the 9 remains excluded, in the third layout the transparency of the lines from 1 to 7, 9 and 10 and remains excluded the 8 and so on.
there is no automatic, if in each layout you have to highlight All the lines of certain layers assigns "transparency window" in each layout.
