print settings for pdf from drw
  • Thread starter Thread starter leleallariscossa
leleallariscossa
Hello everyone, I looked in the forum but I did not find exactly my problem.
I have found many ways to set the creo pens for creating pdf (use 6.0), but actually my need is to manage those print on paper.
I'll explain better. creating from the table the pdf I need to reduce the thickness of the texts both of the notes and quotas etc. How do I do that? especially, what thickness do you recommend me to be normal to reading drawings?
the other problem concerns the lines of the geometries and the cartilage etc. in the pdf are correct by setting the display of the fine lines with the classic ctrl+5, but the print is made with the big lines.
How can I set everything?
Thank you all.
