Tequila
I did a research, but I didn't find what I'm looking for.
I have a dwg file of the plant planimetry where I work to print on the escape/exodus routes for safety. the frame where it has to be put has special dimensions i.e. 1002x720 and I have the need to print this plan of this size, so that by placing the sheet on the edges of the cartilage I remain 1002x720 mm.
for the sheet there are no problems, the plotter is an a0 for which it holds 1198x841
I never did, and even if I looked at autocad's help, I can't find what I need to set the press. Do you have an idea how this problem can be solved? I use autocad 2009 lt
thanks in advance
thanks in advance
