Hi! I think I have some issues with the press in revit 2009. The plants are 1:50 scale, but when the moulds come out very small, I don't even know what scale it is. Where am I wrong? What do I do?
Thank you!
Thank you, but I've already looked. In my case I have to print a4 so I have already defined it, and still the prints come very small.... I don't understand.
in fact the problem is other.... when I open the plant itself the design appears very small, although there is written that the scale is at 1:50. According to me, the problem is with the 4 "points" that define the prospetti, they are put very woolen by the design itself (which is small- is a total surface project of 40mq), and therefore the print also inculdes them, and the design becomes small and does not correspond to the scale. Is there a possibility to move them?
I hope I'm clear enough. Thank you so much again.
it is possible that there are hidden objects, that move the "center" of the view
when you are in the window (view) of prospectus, activate the command "suitable to the window" (set dx mouse)
if the design does not place at the center of the view window, activate the bulb (reserve of the tools below) to see any hidden objects, and delete them
