priority in osnap
mir
for you can manage priorities in osnap? I might want to join the center of two circles: at the first click I find the center while at the second click I would go by default perpendicular to the circumference!
useful advice?
I don't think you can prioritize a snap rather than another.. but if you have difficulty taking the center positioned nearby and press the "tab" key of the keyboard and autocad will show you one by one the snaps possible near the pointer.
great and useful ... I also discovered the use of tab and right button to have possible osnap
useful advice?
a small tip, many use by default all active snaps, it is much better to use only those we actually use, others stick as you said with the right button... this to avoid preying close by end or things like that.
if then one learns the shortcuts for those 3/4 osnap that uses most frequently, leaving set the osnap that do not "interfer between them", then goes away like a splinter... I leave set only dial, intersection, fine and center (but hangs from habits).
es:
maiusc+tastodx+c per centro
mausc+tastodx+d for perpendicularity
mausc+tastodx+t for tangent
maiusc+tastodx+2 per intermediate point between 2 points
maiusc+tastodx+m per... and others...
are shortcuts that, when they become "automatic", you don't even notice using them. . .
Of course the more you learn, the better you go...
