prismatic maching aiuto!!!
  • Thread starter Thread starter domever92
domever92
hi to all boys I wanted to know how to do more work on multiple floors I mean maybe I have to make a superione pocket and a lower one, the upper one I do quietly while I wanted to know how to rotate the piece to make the lower pocket as in this case.
link: http://img4.imageshack.us/img4/6908/tasche.pnghow do I flip the piece to do the other workmanship? (lower pocket)
thanks to all and good work.
If I'm wrong, I'm sorry. .
to make work on two opposite sides of this particular one needs a repositioning of the piece (at least we do so having 3-axis milling machines). Maybe with a rotary table milling machine you should be able to do everything.
However in my case I create two working groups with two axle systems. So it's like I created two distinct and separate jobs.
I have seen that it is possible to reposition the axes in the same working group but this I think depends on the type of milling machine that is available, in this case it would be interesting to listen to the opinion of someone using this methodology
That's what I was looking for, I wanted to know how to fix axes and create a second process of labor because this part of catia v5 I'm trying to learn now. If you could explain to me somehow how you do I'm grateful. Good job. .
once created the first processing group I make paste copy. .
I go to the second processing group just created, I renounce it and I enter it..... I change the axle system (usually in the catpart I create the axle systems that I will use for milling and then I will select in the working group the piece) and change the safety plan... by paste copying you will always work on the same catpart (or catproduct)
I did not understand how rough the piece and change the axes of the machine to work the piece.. with some screen or video maybe I understand better.. another aid please are apppena entered the maching prismatic world of catia v5.. and they're at first. Excuse me so much. .
if interested I was invited to this webinar on the cam by the following partner.
these are details to access the web + phone call with green number.
I participate.
event address for waites: https://3ds.webex.com/3ds/onstage/g.php?t=a&d=707895318 Participant code: 958521
local - italia, milano: +39 02 3604 6338
local - italia, roma: +39 06 4521 7195
Green number 800 088 740
