d_bordin
Good morning to all, I write to you why I should solve a problem of table putting on pro-e.
I created with the sheetmetal a bracket that I should represent on the table in two versions:
a "developed", the other as finished piece, then bent.
I know that you can create this dual display of the same model by associating with a 2d view different simplified representations created in the model.
the problem is that while having created a new simplified representation in the model, when I go in drw environment, I select the view, I open the property panel, and I go on "state view" (state of view), it does not allow me to change the type of simplified representation I have previously created in the model.. .
Would someone please tell me why?
thanks in advance to all!
Daniele
Daniele
