Pro animation, joint animation
  • Thread starter Thread starter makeng
makeng
Hello, everyone.
I ask for help regarding the animation module in creo1. My set is already a dynamic set where there are some cinematic constraints. So I can move with the "manina" what I want.
When I enter into animation I get angry with the "snapshots" . I continue to photograph in different positions, if I make regenerates it makes me see the different movements, but when it comes to creating the animation everything remains inanimate despite the indicator of the time moves .
I forgot to write that animation is about a gear system: so nothing moves but objects rotate.....
but when I do the same procedure for translation movements I have no problem and the animation is correct. If I rotate a gear and click several snapshots I don't animate anything....with this you tell me that in the case of rotation I have to define a servo motor?
Yes, it is good to define the servomotors where you indicate the characteristics of the movements, this also applies to the translation
