pro e - solid edge
  • Thread starter Thread starter davide259
davide259
Good evening,
Is there a tool/macro/software that allows a file created with solid edge (.part and .asm) to be converted into the proe format without losing all the features of creation of the model? (excavations, holes, threads etc... and joint constraints) if model a particular with s.e. then I have to convert it into iges or step to be able to open it with proes but of course it is seen only as a single block and you can not forget/change the various fetures of creation. . . .
grace to all.
davide
Good evening,
grace to all.
davide
that I know does not exist, but you should ask in the section dedicated to pro\e for a more complete answer.
