Bibbitaro
Good morning, everyone.
I'm drawing a rotary machine.
in such machine is assembled a cam used to give a vertical lift to a spindle.
A rotational movement should be associated with a vertical one.
Now, in mechanism design I cannot make the cam work in question as the software does not recognize the path of cam lift (it recognizes it only if straight and not wrapped).
If I go to associate the surface of the cam follower with the surfaces of the cam, the bond fails.
I was wondering if any of you have any experience about it or have a technique to suggest.
on the site of the ptc there is something, but the procedure is to say little laborious.
Hello and thank you.
Fabrious.
Fabrious.
