problem abbreviations with autocad 2009
  • Thread starter Thread starter quattrox
quattrox
I had lost the acadious file.pad, so I didn't get the samples anymore, somehow I managed to put it, but now the strange thing is that I don't get the shortcuts from the keyboard because.
For example if I write: l, pl, of not taking anything (before yes) but if I write line it takes it, why does this do? ?
Yes, I solved the sample, but how do I make them recognize the abbreviations again?
He's the one alias commands are inserted in the file acad.pgp that to be loaded automatically must reside in a folder of the autocad path.
Since that file "by itself" does not move and even the paths self-eliminate the thing is quite strange.
try searching the folder in the pc that contains it and verify that the same is indicated in the options\file\support file search path.
Keep in mind that these problems are also solved with a "repair" of autocad.
