andrea.ruggio
After I insert this code into the html page, I resolve the white page problem, but it gives me permission denied a script
hi, I tried to run this procedure but at the time of saving the file as html by replacing it to the original html, first it does not appear between saving options like html , second saving it as a note block file tells me denied access and does not let me save it . Thank you.the solution for me was to enter in c:\program files\common files\autodesk shared\adlm\r1\it-it\webdepot , which is where the htmls register is stored (this is the pages that the screen shows on white).
open the rtbeginreg.html in a text editor like blocknote. add the following code row below:
<!-- saved from url=(0016)http://localhost --
this marks the page as safe. save by name as 'html' and you should be able to enter the code.
