ansyolitico
I'm trying to make a thermal simulation
I have a resistance of 40 w which has to heat a block of metals...as loads I used generation of internal heat calculated with power/volume resistance i.e. 40/770=0.05 w/mm3, the other load I used the natural convention air 22 w/mm2 applied on the 6 faces of the block...the problem that in the simulation as a result the block does not exceed 50 degrees while in reality comes over 260... what is wrong?
