davide.canzanella
Good morning to all,
I am a neophyte of catia v5. I was asked, however, to solve a problem which at first glance seems difficult ( given my lack of experience) .
I was provided with the cad model of a automotive muffler built through surfaces.since we should implement this model in another software, I need to make solid the above model. I did a "turn" on the site and found a "procedura" in shape design; or to select all the superfficies use the join and then the compose.
After some time searching I found these commands. My problem is that when I "mit" in shape design I try to open my model, to edit, but caia opens it as "product" so I can't (or better I can't do) use the procedure described before.
Can you enlighten me? ?
