problem cgr
  • Thread starter Thread starter Pierandrea58
Pierandrea58
Good morning to all
I have a problem in opening a product: lost 99% of links
the product has a thousand parts
Can someone tell me how I can reset the cgr file?
catia, if not mistaken, you save a file with the path of the product components and should be the cgr
this file uses it to speed up the subsequent reopening of the product
Am I wrong?
Hi pierandrea,
I think you want to clear the cache:
menu/instruments/options/infrastructure/product structure/cache management/local cache path
there you find the cache path, which then from windows the gates, you may find difficulty because it is huge or long names, but insist.
Obviously if you have thousands of parts, you should reopen them and make them load in the block cache if not you plant everything (or use the batch utility)
if you do not refer to the cache but you have them in folders apart as cgr that have passed you (thirds) in the projects then do not delete them and repair
Let me know.
also check the size of the cache folder, if it exceeds the one set in the options, it could get you load problems (at least it happened to me); in case or increase the size from the options or delete the folder as already indicated (it is good to do so occasionally)
Thank you for the answers
Today I didn't have time to work
I'll let you know
