problem change ucs gives modello to layout
  • Thread starter Thread starter Ucp1985
Ucp1985
hello to all, I have a problem:
in a few words, for convenience, I created a ucs of "work" . so far all good.
the problem is when I step from layout to pattern, view or ucs that you want, I go crazy as it only shows me a line, changing my view.
the same file, opened by another autocad or other pcs does not give me this problem, so it must be necessarily a variable or something to set up on my autocad.
impotent thing, that if I have ucs word, step from model to layaout and then again to model, nothing happens, remains the correct view, so the problem is only when I create a uucs work on my autocad.
thanks to all in advance
claudio
update:
I noticed that the above mentioned problem you have with autocad 2013 map3d with operating system windows 7.
already passing from windows 7 to xp the problem disappears.
I also tried to install the service pack but the problem exists.
no one else to see my problem?
