Problem chewing book bearings
  • Thread starter Thread starter Vit1
Vit1
Good evening, guys. I have a problem with bearings in the _amplbear2d command.
the problem is that the inner and outer ring of the bearing are separated with the same automatic hold, while they should have a different hold. is there any way to solve the problem more "selectively" than to paste on a white background (so that "cover" in print when there is below?
Thank you!
