problem command rigen and undeleteable lattice in autocad 2017
starsun
hi friends, excuse the very trivial question but I just can't find the command regenerates and regenerates everything in autocad 2017.... help me? Thank you very much.
I used rigen and rigent, and it went... I remain doubtful about a possible button that was in previous versions and that now I do not find... boys the problem is also that this project was made with an old version of autocad and now 2017 sees it full of lattice that I can't delete.... help!
for the button you have to do:
fast method:
1- Right button on a toolbar
2-choice customization
3-search the command and drag it into the bar you prefer (the icon could be a question mark)
method with multiple steps but more customizable:
1- menu tools>personality> interface
2- expand the toolbar entry
3- expand the toolbar where you want to place the icon
4- in command list search command
5- If you didn't make it expand the right window with the arrow you find at the bottom right
6- Select an icon or draw it
7- drag them into the toolbar you expanded to point 3
methods made with classic (or old) mode and not with ribbons I never used. otherwise assign a key through the acad.pgp
What are the lattice?
Thank you so much!! I uploaded a jpeg that gives the idea of my problem, in essence they are lines that I can't remove, that sometimes zooming away (some), a very annoying thing... As soon as I open the file, autocad tells me that it is a file made with an old version and highlights an aec problem, I basically care about recovering the files, otherwise I have to back it up and I think it's crazy...
first to attach images uses the special tool of the foruum (read here http://www.cad3d.it/forum1/faq.php?faq=vb3_reading_posting#faq_vb3_attachments)
for aec read here http://it.comp.software.cad.narkive.com/cherq50h/aec-qualcuno-ne-sa-qualcosabut should not be the problem of the lines. typically they are objects derived from other applications or versions of the program (me happened with autocad mechanical files)
Can you select the lines? because it could be a graphic acceleration problem activated.
I am very new in this forum and I did not know about the attachments :)
I will do as you say for the future.. .
I think you're right about the graphics acceleration because I can't select them!
So, as far as I understand, should I turn off the graphics acceleration? in these things I lose myself as I resumed autocad after
A lot of time. .
You're great! I disabled and now it's all perfect!!!! Listen, but this problem I only found it with these old files, which save them again become "new" (last autocad version), if instead design ex novo I have no problems of acceleration as ever?
solved: I disabled the graphics acceleration, I made a copy of the old file design and a paste on a new file, so I reactivated the acceleration and now it's all perfect! technological mysteries... evidently that file was obsolete for the new autocad...
Thank you very much
