problem con serie fori su ipart
  • Thread starter Thread starter stefra
stefra
Good evening, everyone!
I have the following problem with the attached file : I have to create a series of panels with a base which increases by 170 mm per panel; on these I have to create a series of holes (with a step less than 500 mm) which increases when the length increases.
I have created an ipart with table in which I tried to set parameters that change the set of holes , but when step from measure 308x1158 to 308x1328 I close the inventor and crashes... :mad:
any advice is accepted! :confused:
I tried and crashed, too.
I don't see any heroes, it might be or the broken file, or something that doesn't act well (sometimes stupid like parametric structuring)
I had something similar to the processing level and I re-proposed it with your measurements.
I don't know if that was what you were looking for.
by Pompeo79, first of all thanks for the attention;
I tried your file and it works perfectly!
I probably screwed up with too many sketches and parameters.
Your solution is much simpler and more linear. :finger:
I do not understand why on the expression of n_fori add +1.5 on at the end.
thanks again and hello
Hi stefra,
should be 1 theoretically (minimum length/length) + 1 , being two holes outside the measurement.
1.5 basically as a correction factor
for example in case with base 818
the holes should be 3, but if instead of 1.5 I had put 1 I would 2.27 (which inventor rounds to 2)
with 1.5 I 2.77 inventor round to 3,
the same for the other holes, since the increase is constant, 170 mm, always satisfying the condition distance holes <500
Hi stefra,
the holes should be 3, but if instead of 1.5 I had put 1 I would 2.27 (which inventor rounds to 2)u
with 1.5 I 2.77 inventor round 3
to overcome the decimal problem there are parameters to be inserted in the formulas that allow you to round for excess or defect. Look at you. This is what debate
