16fra
Hello everyone,
I have to export rhino files to open them to a company that works exclusively with jewelcad (and possibly 3design). .
jewelcad opens only 4 types of files, its propretator, .dxf, .igs, .stl.
I would like to export rhino models to .igs so that it retains the essential surfaces and properties of the model, so that they can possibly change the geometries without major inconvenience.
the problem is that if I convert to .igs when I open it in jewelcad I find all the primitive geometries I used intersected (as if he had lost the trim).
I tried to export to .igs also using other software (sw, ptc creo), the result on jewelcad is quite similar.
the .igs files that I generated imported on rhino are entirely correct. . .
before delivering mesh models (.stl) do you have suggestions so that it can get models in closed .igs? Does anyone know jewelcad? ?
