problem copy-body autoca-inventor 2013
  • Thread starter Thread starter Paolotex
Paolotex
Hi, I've been talking to autodesk support for several days, but we haven't come to the end.
I passed from inventor 2011 (where everything worked) to factory suite 2013.
the problem is that I can't copy from autocad and paste on inventor sketch environment. Moreover if from inventor I try to import a dwg file (always in sketchy environment) this does not charge it.
we tried to re-start, to verify that the conversion dll is loaded and to lodge with other user (so to rewrite the registry file), but the problem persists.
I add that the operating system is seven and that the graphics card is nvidia picture 600 hp memory ram 16 giga.
I desperately seek help because the next thing to do is to reset the car from scratch... thank you.
I solved the problem by installing again 2011, but using 2013. I think there's a kiss in 2013.
Hello, everyone.
I installed inventor 2013 + autocad 2013 in an operating system windows 8 but unfortunately I see that does not work well copy/paste from autocad in environment sketch inventor.
I think the problem has the inventor because in autocad the paste copy works without problems.
I can't even do the dxf/swg salvage from inventor in autocad.
What can I do?
Help!
said an old Chinese essay "the time that you want to share a sketch copied by inventol is semple Mayle of what you employ x foul as head". :wink:
INCOLLA.webpI wanted to report something really interesting:
I don't know if there had always been and I never noticed or is due to some service pack recently downloaded, however if after ctrl+v press the right mouse button appears a "gluing options". the command allows to apply geometric constraints automatically, bind the final points and a couple of other things. Try it.
at this moment I have no inventor under my hand but if I don't remember badly, in the sketch environment, if you go into the tab enter --> acad --> options, you should exit that window. I tried several times to use this procedure but I don't see anything good...
