problem copy paste autocad 2011
  • Thread starter Thread starter fab86
fab86
First of all, hello to all.. .
I wanted to tell you about a problem encountered in autocad 2011 that in theory should have been solved by a fix released by the autodesk around 2009 I think...
the problem is this...I have a pretty heavy file, a cartography to which 3 external references are connected...the problem of the file is that to copy and paste you objects you must first download all external references, save, close, reopen and paste what you wanted to copy... until here all right, if it wasn't for the fact that now I would need to go to systematically edit one of the external references. .
the problem is that the files are very heavy and I can not change them with xref directly on autocad...and also wanting to change them separately, I need to work with more people, but in the files you can not paste anything that does not come from the file itself. . .
I read that the problem arises from a problem of different scales...and the patch that releases autodesk is the cleanupscale should solve the problem...but it does not work. .
do you have any solutions? I have tried everything...of course I have already tried to copy the file on a new file, rename it, edit it as external reference...and these are only basic attempts. .
I also tried with the Scallistedit command, but it doesn't work out.. .
Does anyone have any useful information?
I need to work with more people, but in files you can't paste anything that doesn't come from the file itself. . .
I don't know how to answer your problem, at least not now, but... talk about more people at the same time.
You mean this?
yes the problem is that I have to work for an examination of urbanism with more people...and we need to copy and paste the various parts designed on a single file...but so it is impossible. . .
