elpado6872
Good morning to all I am a mechanical engineering student and I have a problem with solidworks 2010 64 bit.
In practice I had to correct a library that was inserted in a part of which I had made the 2d file and in the .slddraw went all in place aside for the fact that the odds became yellow as when there is an error, but apparently there are no errors as the odds can quietly edit or move and solidworks does not report any error.
I would therefore like to know if it is a problem and if there is a way to get her back gray.
Obviously if I cancel the quota and I remake the new quota is gray as usual, but it does not seem to me the best solution since then I should remake everything and the drawings are not few. Thank you all. Hi.
