ecomusposta
Hi, guys, I'm back here breaking up.
I happen to have a strange problem in rhino 4.0, I want how you see it in the attached file from me, create a boolean difference between 2 patch surface. I don't understand why sometimes the program creates a difference in a quiet way, sometimes not, like in this case, if I'm wrong, could you take a look at it? Do you think it's a program debug? I tried a thousand times but I don't get it. I did an analysis of the two surfaces and it was regular. Where am I wrong? thanks in advance.
p.s. the program does not tell me difference boolean failed, he goes ahead with the operation but the result is not the hole in the center of the figure, but the hole is not seen, in poor words does not create it.
