problem file opening in separate session of autocad
  • Thread starter Thread starter ilbona
ilbona
Hello, use autocad lt2015. cause some errors I reinstalled the program and resolved. Now I have this problem: If I open autocad and open a double-click file on the icon, instead of opening it inside the interface by adding a tab, it opens the program again. and so for all subsequent files.... :confused:
advice on troubleshooting the problem? ? ?
Okay solved thank you. tast dx on dwg icon ---> open with ----> default program ---> I had set to autocad dwg launcher instead of autocad lt application. thank you massi...
