problem import model cad from the site skf in catiav5r21
  • Thread starter Thread starter arkantos93
arkantos93
Hello everyone,
I open this discussion, not having found anything like that.
I am carrying out an exercise of an overall transmission of axial motion and I have to add bearings.
to avoid creating them, I was given the site skf.com from which to pick up models cad.
However, after selecting the suitable bearing and having saved it in the casket format, I go to double-click on the file and, bringing me to catia itself, I exit a window with the following message: "save as" enter path for catpart or catproduct (e.g. c:\catfiles\).
under this, a white space to write something... but whatever I write, pressing ok, returns to the screen without adding anything.. .
What to do?
thank you in advance for your answers! :
if you need I attach the image of the file to perform the full modeling, in top-down. Just ask.
when I don't remember the possibility of a command position the pointer in the field and I click the button dx and the options appear to me... Try it, maybe it helps you.
nada, I had already tried to turn between the various menu commands; in an article I found something on the macros, obviously in english, but I didn't understand anything.. .
p.s. I forgot to specify that the file in question is a .catscript
If you tell me about catscript, you remind me that it had happened to me with different behaviors (it worked or not) depending on the work station I connected with, which makes me think I need a particular set. . I have always solved the problem by importing a step instead of catpart, so much they are always explicit and not parametric solids. If you want, I'll send you to the Parametric Gears.
How do I import the step? I'm sorry, but I'm novice, so I'm pretty Arabic.
I wouldn't mind having them. always convenient some extra material
It is very simple on the site choose to save in step (usually there is) then open it directly with catia and save it as catpart. send me to pm your email address that I send them.
I have found that the problem is solved by inserting in the dialog box a valid path for your computer where you want to store files
(type for e.g. c:\users\public\cuscinetti)
the script will start by copying the files to that folder.
