ygna
Hello I have a small problem:
After constructing the whole model with loads and constraints in allowing the analysis I realized that the solid 65 element is not compatible with the isotropic material (in the model I have masonry and wooden cover) it is possible to make some modification without having to re-enter all the constraints if you insert another element also with eight knots? ...
thanks in advance
thanks in advance
