problem in using layouts
  • Thread starter Thread starter kar89n
kar89n
hi I am new in this forum, I wanted to ask if someone knew how to put in cartiglio a4 from a 3d design, (use autocad 2005, I also have 2013 but at school you use this :p), you should bring in layout but I don't know how, i.e. I can but it is not correct as a technical design must be.
ask too general yours. you are on the good road with regard to the layouts, but perhaps it is better than before you read some tutorials on the topic, about there are many. then you say that you can but it is not correct, you don't even explain what and in what sense it is not correct. so we can't help you.
I said the way I use it would be to import 3d design windows on the layout, I don't know if I explain, cmq I try to look at or read some tutorials.
