problem installation 3ds max 2013
  • Thread starter Thread starter grukikko
grukikko
I press that it is the first time I write in this forum, so I apologize for any errors.
cmq the problem is this:
I tried to install 3ds max 2013. At some point the installation fails. in the setup.log file among the many writings there is this:
2012/10/13:17:00:52 grukikko pc-grukikko rollback autodesk material library 2013 - medium resolution library succeed
2012/10/13:17:02:27 grukikko pc-grukikko rollback autodesk material library 2013 - base image library succeed
2012/10/13:17:04:50 grukikko pc-grukikko rollback autodesk material library 2013 succeed
2012/10/13:17:04:50 grukikko pc-grukikko rollback directx® runtime failed failure is ignored, result=1619
2012/10/13:17:04:50 grukikko pc-grukikko rollback microsoft visual c++ 2010 sp1 redistributable (x86) failed installation aborted, result=1619
I can't solve this problem....you know what to do?
try installing directx runtime and visual c++ 2010 redistributable before launching the 3ds max setup
