problem on rescue party parts
  • Thread starter Thread starter tonypezz
tonypezz
Hello everyone, the problem is this, I find myself a part to duplicate several times, so instead of doing the copy and paste, I did the operation of multiple recurrence, now I got what I wanted, and I am now 55 of these recurrences, the problem arises when I go to save, in rescue management, there is no present of these parts, but only the parent part and the product.
Besides, I need each of these occasions to have no connection with the father part.
is an operation I have to do with 2 products,
As for the first I solved so, I copied all the occurrences present under the logical tree, and I glued them under a new product with special glue-interrupt connection, so doing, I saw that in rescue management appeared all these parts with name "copy of 1,2,3.ecc
I saved all my parts by changing his name.
As for the second product, I glue special without connection, and gives me a strange error, " the header is null".
How do I solve this? I find no way to save the work done.
How can I do that?
It is obvious that if you use in product environment the second matrix repeat means that you are replicating a father object for n times, and it is obvious that in rescue management you find only a part and a product where repetition is defintia.
in the tail of the tree you find the definition of the matrix so through the double clik you can enter the definition of the matrix and exclude some of the repetitions if you have to replace only part of these with secondary elemetes.
If necessary the replacement of a part you can use the comado replace together.
I advise you to use the copy/paste command, however the type of error seems more related to a copy command destination error.
