Ciuchin0
I have to create the underground ramp.
the road is that with blue lines, the greens are lines of reference from me created. the width is about 5.5 meters, the internal bending radius 4.5.
I have to climb to the upper floor both roads that reach the ramp, tilted between them about 90°.
the sloped ramp for exit from the basement I can comfortably create it straight but not with a "curve" part we say.
If I check the side of the curved ramp tells me that it can't create it, if I check the direction of curved ramp, it creates it but then I can't complete the straight piece to get even those of the straight road to dx, if the drawings the curved lifts tells me that you can't use the curves for the lifts.
In short, how can I create a ramp that allows both internal roads to climb?
the difference in height is 3,10 mt and the green circle I have drawn it because it is the limit of slight slope that I can use.
thanks for the advice.
