problem opening new part/axis/drawing
TheFlyer
good evening to all, I write you because after three days of defeat I failed to solve this problem alone and not even with other posts of the forum..
As soon as I press on the 'new' icon, I start to slow down to the inverosimile and the mouse dart turns into the loading circle. I tried to leave him so fearing it was a problem of lag but after forty minutes of loading I didn't solve anything at all.
However I can open already designed parts and change them as I want. in practice I can no longer create parts, assembling them, or new designs because you plant everything and touch me to close sw from the task management screen. at nothing it served uninstalling and reinstalling or restoring sw. I also tried to work disabling the antivirus but nothing. Is anyone already facing this problem and can you suggest a solution?
Thank you in advance for your help and wish you a good day, given the time.
ps I am a beginner and self-taught student so I would beg you to have a lot of patience in case you could not understand all your answers properly, thank you!
use sw with a student design kit 2016 and my computer has the following features:
windows 10 pro 64 bit
intel core i7-4700hq cpu 2400ghz
8.0 gb ram
intel hd graphics 4600
using another computer with sw found only today I managed to solve the problem: in the settings> models of the documents were present two voices instead of only one and evidently went into conflict when trying to create a new file.
I'll write the solution if you need someone else with my own problem.
thanks to all and good day!
