problem osnap
  • Thread starter Thread starter diego schiavi
diego schiavi
Hello.
I have a problem I can't fix. I installed autocad 2016, and until recently I used 2009.
with autocad 2009, if I had to draw for example a polylinea partedo from one point to a certain distance from the top of another polyline, with activated osnap I did: polylinea command, I positioned myself on the top, I went in the direction of extending the straight, and inserting the distance from this summit and sending me the new polylinea just from that distance. now I do the same thing but polylinea leaves me from any point of indefinite space that changes from time to time doing the same procedure. explain why please?
disability
Try to see if you solve this:
dsettings
Dynamic input
input pointer settings
check to have set relative coordinates (I also let polar format)
