Hi, I would like to know if you can recover autocad drawings in an unfunctioning pc, I explain, my pc no longer lights up and I had important tables, can you recover using the account I had?
If you remove the disk and connect it to another pc you should see it as a normal memory and move the dwg where you prefer, unless you have encrypted the files or used any kind of vault.
The account has nothing to do with it. Don't worry about your account
to connect a disk to a pc so that it acts as an external disk (to recover data) there are special adapters. with little expense you can recover files from a disk that was mounted on an old pc.
in the video below, for example, it is about recovering data from an old hardisk quickly.
